Lovers don't save
memorandum
Hi, lovers do not save for no reason. I could not understand the problem. When drawing multiple crosses, even though I say 2, it throws 4 crosses and how can I correct the error in the girths. Good work.
Hello there; Your purlins are insufficient due to the deflection problem. There is a program bug related to deflection in version 8.61, so if you remove purlins from analysis and split by intersections or remove consoles in your project, the problem will be fixed. In your project, I removed the lovers from the analysis and arranged them in one piece. In this state, you can reduce the cross section because the strength rates are also very low. Due to this error, a new version is being worked on. During this period, if you wish, you can continue to use 8.504 or produce solutions as I mentioned. You can download 8.504 again from the link
. ** If you are modeling multiple crosses for scissors in the menu that comes before you during modeling, the value you enter from the menu is not the number of crosses, but the number of jumps of the scissor node points. Therefore, when you make 2 entries, 4 crosses are formed. If you enter 4, 2 crosses will be formed. Good work.
Thank you Nurgul. There is one more issue. It has been discussed before but no answer has been written as a solution and I missed it. When I save the report as pdf, the report is closed. I cannot open it with the RPT extension, even though I have downloaded a few different programs. good work.
"nurgulkaya":1gbmdmpz" said:
Hi; Your purlins are insufficient due to deflection problem. There is a program error related to deflection in version 8.61, so if you remove purlins from analysis and not split by intersections or remove consoles, the problem will be fixed. In your project, I removed purlins from analysis and they are one piece In this state, you can reduce the cross-section because the strength rates are also very low. A new version is being worked on due to this error. During this time, if you wish, you can continue to use 8.504 or produce solutions as I have stated.
** If it's about multi-cross, in the menu that comes before you while modelling, you can add multiple scissors to the scissors. If you are modeling cross, the value you enter from the menu is not the number of crosses, but the number of jumps of the truss node points.Therefore, when you make 2 entries, 4 crosses are formed. ir. If you enter 4, 2 crosses will be formed. Good work.
Hello. I wonder if the program error mentioned about the 8.61 version was resolved with the 8.62 version? Or should we work with version 8.504 for similar problems?
