bektasmehmetali
Hello, I am making designs similar to the file I uploaded in order to do steel works with idecad. My questions are as follows; I want to add a connection for 1-stabilized beam, but I can't add a connection to the end trusses. The program wants a 3rd element (while adding this connection in the middle; I was choosing the truss and the beams at the other two ends and creating the connection, but it does not occur because there is a truss and a single steel beam at the ends). .I couldn't do it or is there a problem with the program? 2- When I get the steel report, although I increase the purlin section each time (I even used box.70.6 profile and I think the section is too much for this opening), I still get the error "deflection exceeded". Is it due to lack of connection or is there another problem. Other than that, is there a design or add-ons you can suggest for such a cage? Thank you
