muhendis_gokhan
Greetings to everyone, In normal reinforced concrete structures, our project is hollow block, that is, our beam height is 30 cm. According to my observations in several projects that I have heard and seen, men crossed 13 meters with a beam of 30 cm in height. They used beam dimensions of 30 cm and 120-130 cm or something. But even if the width is 120, as the beam height is 30 cm, shouldn't our length be 1/15 in the inner beams according to the regulation, since the beam height is 30 cm? I mean, I have projects where I exceed 7-8 meters with 30 cm, but 13 meters is a very large span... How can we operate such a beam without any problems, and on the basis of which directive is a project with such beams approved? I would like to thank you in advance for your help, especially if there is a friend who uses this type of beam and has his project approved... :?: :?:
