Greetings, As far as I understand, column calculations are made for the lower and upper ends of the column. In structures with basement or basement-like shears, maximum moment occurs on the shear. The solution to this situation is to define a floor at the basement level, or is there a way to specify the point in the column where moment calculations will be made, or am I doing something wrong? Thanks
