Loads on the Beam
yldrmanil
Hello, I am drawing wall on beam and it is loading in this analysis. At the same time, when I define a user-defined wall load for the beam, it does not add up the two and takes the load of the wall I drew. Is it possible to collect these loads?
Hello. If there is a wall drawn with the wall object on the beam, the loads are calculated from the wall object settings. The wall load entered in the beam settings is not taken into account. If there is no wall object drawn on the beam, the wall load is calculated with the values entered in the beam settings. Both loads are ignored. It has been done this way to avoid accidental duplication. You can get information from the help.
I wondered; If you have defined the wall on the beam, if the program calculates the self-load of the beam itself, what kind of load did it need to enter on that beam? NY
