Hello, in the Earthquake Code it says that the 30% contribution of the earthquake in the other vertical direction should be taken into account for combinations with earthquakes (Article: 2.7.5). So the seismic combinations are 1.0G + 1.0Q + 1.0Ex + 0.3Ey 1.0G + 1.0Q + 1.0Ey + 0.3Ex and even 0.9G + 1 ,0Ex + 0.3Ey 0.9G + 1.0Ey + 0.3Ex Does the program take this into account? It seems that it does not receive when writing combinations in reports. ---------------------------------------------------------------- ---------------------------------------------------------------- ----------------- There are also expressions and combinations in the combinations for earth thrust as follows. 1.4G+1.6Q+1.6HX1 ±HX1, HX2 : X direction earth thrust 1.4G+1.6Q+1.6HY1 ±HY1, HY2 : Y direction earth thrust 0.9G+1.6HX1 0.9G+1.6HY1 Now, here are two questions there is. 1- The so-called soil thrust does not affect the structure separately from x and y directions. In whichever direction there is soil, they all affect and load the structure at the same time. Loading it separately by dividing it into aspects such as earthquakes can sometimes lead to negative and sometimes positive situations, and it is not true to reality. It is necessary to make a distinction to define the charges, this is understandable, but they must all act together in the solution or combination. So it should be like this 1.4G+1.6Q+1.6H (Hx and Hy together) 2- There are also ±HX1 and ±HY1 expressions. These are perceived as the effect of the soil from opposite directions, ±. Is it possible for the soil thrust to act in the opposite direction? Of course not possible, then what do these ± expressions mean? Good work.
