izmirlimuhendis
I enter the beam load library. from the load library, for example, I change the unit weight of the perforated brick in the beam load layer section of the 19 cm brick in the beam load name section, but this time it is the same as when I change the unit load on the 13 cm brick, which is my other load definition, so the program automatically changes it as well. there is a problem but i couldn't solve it
