Live load on beams
Muhpen
Hi, there is a floating height option in the Beam settings-Static/Reinforced Concrete tab. This option appears to be 0 by default. Do I need to define live load on beams other than the live load I give to the floors?
"Muhpen":7pp7ubd2" said:
Hello Beam settings-Static/Reinforced Concrete tab has a floating height option. This option is set to 0 by default. Do I need to define live load for beams other than the live load I give to the slabs?
Hello, if the beam If there is no wall on it, you must enter the live load value.
