Linear Performance Analysis Report
EmreT
After performing a linear performance analysis, the report window opens on the screen. If we turn this off, can't we access the report from the report tab afterwards?
Hello, After the performance analysis, the report receiving screen opens automatically. After receiving the report, it is necessary to perform a performance analysis again to get it again. Can't there be a "performance report" button on the reports tab for that? Again, to get the final report without analyzing... I also have a question and a request: 1- In article 15.7.1.4 of the regulation, it is stipulated that the upper limits of strain should be reduced by considering the shear force ratio. Does ideCAD do this check? I couldn't see it in the report... 2- In the building performance evaluation report, where it says "BUILDING PERFORMANCE:", it would be useful to note that if there are brittle elements along with the performance status, they should be strengthened. Also, if the names and multiples of the crisp elements are given in summary form, it speeds up the work.
Hello there; To get a performance analysis report for the second time, it is necessary to perform a performance analysis again. Necessary notes have been taken regarding TBDY 15.7.1.4. Necessary adjustments will be made in the reports regarding this situation. We specify brittle elements in the reports under the heading "Performance analysis column/beam ductility control". Your request to list the brittle elements with their names will be considered. Best regards...
"oguzcan":hhipkyns" said:
We specify the brittle elements in the reports under the heading "Performance analysis column/beam ductility control". Your request to list the brittle elements with their names will be considered. Best regards...
I have already stated this in my message. But It's quite time consuming to check thousands of pages and look for which ones yield crispy results.
Hello Mr. Emre; If you save the report as pdf or rpt after receiving it, you will not need to analyze again. Do you have any other request? Good work.
Hello, Ms. Nurgül, Isn't the external column load shown in the performance analysis report? In cases where a steel floor etc. is added to the structure, we enter the external load on the column.
