hello, a performance analysis of the current situation of the building was requested for the license procedures of the illegally constructed building within the framework of a certain project. The building consists of floor permit, basement, mezzanine and 13 normal floors, and when the municipality stopped the construction after the 4th normal floor, the citizen asked me for a performance analysis. Core samples were taken from each floor up to the fourth floor, reinforcements were determined and surveyed from top to bottom. I did the modeling in idecad as follows: 1- All floors up to the 4th floor were drawn according to the survey. The concrete material was defined for columns, beams, curtains and slabs according to the core results. The reinforcements fixed with the device were also entered and 'fixed' in the reinforced concrete tabs of the elements. 2- After the 4th floor, each floor was entered as a new project. After the 4th floor, I entered the same column-beams in the upper floors so that c30 concrete was used, only as a cross section, but I did not interfere with the reinforcement. (no reinforcement, fixing, etc.) 3- I made a static analysis. Thus, the reinforced concrete of the floors after 4 was formed. 4- After the static analysis, I locked the reinforcements of all the building elements and started the performance analysis. 1- I wonder if this path I followed is correct? 2-
After the static analysis, there was an E error in almost all the columns in the basement and ground floors, but when I performed the performance analysis, I did not get a brittle warning or an error. How healthy is it, is there something I've overlooked? 3-fold strength seems very, very low to me. is this normal? by the way, 2018 regulation says my performance analysis method should be non-linear method. Due to my computer's ram problem, I chose this method to at least get an idea for now. project link3- I did a static analysis. Thus, the reinforced concrete of the floors after 4 was also formed.
Log in or register now.
