level difference on the floor
isbandam
Hello. Due to some requirements, I was asked to solve the attached building without dilatation, and I could not find a solution by opening floors in the building due to the elevation differences (can it be solved by opening floors?). I would like you to examine whether there is a deficiency in the attached project in terms of data entry and the operating logic of the program. Also, how do we check whether horizontal loads are applied to 2 different diaphragms on the ground floor. The purpose of use is the parking lot and the installations have not been done yet.
Hello, There is no problem in your project in terms of data entry. The block on the right of the 8 axis on the ground floor can also be modeled as a separate floor. Horizontal loads acting on rigid diaphragms can be seen in the Analysis / Floor parameters dialog and in the Floor Forces report. Good work
