Level difference for elevator motor
Karub
Should I enter minus quota tiles here or should I draw autocad by hand without solving it in the idede? If I'm going to do it in idestatic, what kind of way should I follow, thanks in advance.
The attached file contains a modeled elevator tower and its drawings. You can make your own model in a similar way by looking. Note that the floor and beams on which the elevator motor assembly sits are in other layers and at the lower level. After entering these elements, you can close the layers and enter the elements at the upper level. Then open all layers.
I go with a column, not a curtain. If I throw a beam, a short column may occur, but it seems like there is no risk. I am laying the floor by giving jeans, but I wonder if there is any problem before the beam turns, I would be happy if you examine it.
Hello --5. You can put 25/40 beams under the floor by giving an elevation. Flooring on it. --Here the program calculates the short column moment. I think it saves easily. Take it easy Unver ÖZCAN
