Laying Static Results
miralay
I wish you good work. When I examine the static results of the slab (M11, M12, Displacement etc.) in the shell results tab from the three-dimensional window after the analysis, I observe that the static results shown in the Reinforced Concrete design envelope tab are smaller than the 1.4G+1.6Q combination. Shouldn't the reinforced concrete design envelope give the largest (negative) values?
Hello, when you change the combinations from the shell results, the color scale values change automatically. You may have perceived it this way because the color values have changed. You can see the values in the same way when you hover over them with the mouse. If otherwise, please share your project or screenshots with us.
Hello, ideCAD gives the most negative value in the design envelope. In the example you added, we see the positive and negative moment values as the same as the design envelope, since the largest values are found in the combination of 1.4G+1.6Q. Most negative negative value: -0.498 tfm color scale Most negative positive value: +0.385 tfm color scale The most unsuitable values calculated in the system are listed. Check "Show min. values in envelope results" for the most negative negative moment. Do not tick the option. In the example you added, we see the positive and negative moment values as the same as the design envelope, since the largest values are in the combination of 1.4G+1.6Q. Good work
It caught my attention that the displacements gave the same value and the moments were different. Clicking the tab you mentioned fixed it. Thank you.
