Re: For Idecad Program Rigid Analysis, the way the flooring works may change due to the laying conditions and what we call class 5-space. For example, opening large tears on some edges can turn the tile into a console shape. But a simple hole according to the slab size does not change the load transfer pattern. You can watch this from the colored meshes where the post-analysis stresses are shown in the program. It is necessary to pay attention to the gaps, especially in ribbed floors. The ribs should not be cut. 4 - in fact, continuity is essential in rib flooring. In this sense, even if there are cantilever beams on both sides, if there is a rib floor that will provide continuity behind it, it would be more correct to arrange the floor you ask as a console. What is meant by the word load transfer is actually how much bearing capacity the beams press on by the ribs. (horizontal, vertical, stub, long, short, etc.) 3- cassette upholstery teeth and rib teeth are generally different from each other. Between the ribs is filled with light filling material in the market. (styrofoam etc.), however, there are cassette molds in special sizes for cassette floors. Therefore, it is usually not possible to fix the tooth gaps. If all three flooring types are used in a project, it means that there are many different openings and this tooth continuity may not occur. 2- Let's say we have two floors side by side, one 4.8 m and the other 6.6 m. What will you do? In this case, you can do two things: first, you make transverse threads with an interval of, say, 2.3m, divide the first slab approximately in half, and the second slab in three at the same interval and continuously. Secondly, you do not create continuity by dividing both tiles into two. Both of these are true. 1- To summarize briefly and intelligibly: in a rigid solution, it is assumed that the slabs behave perfectly rigid in their planes. However, their real behavior is not like that. That is, the structure does not actually move horizontally from the floor level in the x and y directions. It makes a parabolic movement in space with vertical deformations as well. The influence of the support it is attached to here is also very effective. For example, imagine the behavior of a tile that has one edge pressing against the curtain. (or examine using the analysis model of the program) As it is understood from here, slabs are not actually infinitely rigid as in rigid acceptance. Nowadays, this non-rigid (semi-rigid) behavior of floors can be analyzed thanks to the active features of computer programs. This allows us to find the real structure behavior. This fully rigid issue gains a different dimension in rib slabs. While rib slabs can be considered as rigid in one direction (? I think this is also debatable), in the other direction they can only be as rigid as slab thicknesses. For all these reasons, it is necessary to choose semi-rigid ACCEPTANCE in building solution. I think it's a little more understandable. The TS500's forcing rigid flooring is something different. What is meant to be said there is that it is better to support all sides of the floors as much as possible. Let me answer one more question 1b- If we consider the bearing of the building in reverse, the building is related to the ground, then the first priority element is the foundation. Then the columns and curtains that transfer this load to this foundation. Therefore, shouldn't these columns and curtains be in a certain systematic order? So we don't put all the vertical carriers on one side of the beer, do we? Well, where will the load come from on these vertical carriers, of course, from the beams. The beam-column relationship is important here. Loads should not be moved to the stud beams much inside the building, the beams should be continuous so that the load distribution is smooth. Accordingly, the floors should transfer loads to the beams well. I've been trying to type
from my cell phone for an hour like a chicken feed. Insha'Allah it was helpful. Sent from my SM-N915F using Tapatalk
