Laying bug
zaferuu
Hello, I'm a new idecad user, I'm entering my first project, but it gives an error like 'Double reinforcement is required' in the flooring, I would appreciate if you could help.
Re: ERROR IN FLOOR
"zaferuu":3mm5iun7" said:
Hi, I am a new idecad user, I am entering my first project, but it gives an error as 'Double reinforcement is required' in the flooring, I would appreciate if you could help me.
Add your project Let's see if there is a data error.
Re: ERROR TILE
"zaferuu":zd184m9d" said:
I attached the file, I would appreciate if you could help me. You can download it from the link.
In the basement, the DB05 slab has a problem with the correct formation of the slab because the upper slab edge is not connected to the joists. So the slab analysis is also inaccurate.The problem is fixed when the tile edge and slab are defined correctly.Good work
Re: ERROR IN FLOOR gives a dc error in this project as well and I could not fix it. I will be glad if you help me.. basement floor tiles..
Can you open and examine this project.. I didn't have a chance to fix the PD error on the floors in the basement.. I would appreciate it if you could tell me the solution...
"manyaksel":fh0vo0o8" said:
Can you open and examine this project.. I did not have a chance to fix the dc error on the floors in the basement.. I would appreciate it if you could tell me the solution...
Hello, *ÇD in the floors in the basement (Double reinforcement required) The reason for the warning is that the meshes are not formed correctly during the slab analysis. To solve the problem, connect the P09 panel to the S09 column from the upper left corner. Rebuild the D06 slab. *The meshes are not formed correctly in the slab analysis on the 1st floor, either. To solve the problem, connect the K36 beam to the S09 column from the upper left corner. Draw the eccentricity of the K08 beam as defined from the top.
