Laptop advice
cagan
Do you have a laptop recommendation where I can get quick results with a semi-rigid diaphragm? Thanks Sent from my iPhone using Tapatalk
"cagan":2vwtxr3d" said:
Do you have a recommendation for a laptop that I can get fast results with semi-rigid diaphragm? Brand, screen resolution, weight, etc. Other features depend on your comfort preference.
With i5 processor, 8gb ram, nvidia geforce gt650m video card, is it normal for a laptop with these specifications to take 30 minutes in a semi-rigid solution with a basement + 8 floors (on 4 flats)? How many minutes does this time decrease in the machine you are talking about? Thanks Sent from my iPhone using Tapatalk
"cagan":1a5rh75h" said:
i5 processor, 8gb ram, nvidia geforce gt650m video card. Is it normal for a basement +8 floor (on 4 flats) building to take 30 minutes in a semi-rigid solution with a laptop with these specifications? Thanks Sent from my iPhone using Tapatalk
Depending on the number of nodes, the analysis time may change and the amount of memory required for the analysis may increase. Especially if you are making a solution with semi-rigid diaphragm acceptance, since the tiles participate in the analysis, the number of nodes increases and the duration is fully rigid In addition, if there is a raft without beams in the system and you are solving with superstructure-foundation interaction, the time will be shortened or extended depending on these options. The time you mentioned may be normal.
In the machine you mentioned, how many minutes does this time decrease?[/ quote] It's hard to say that the analysis time is that short. If the system memory is sufficient for analysis, a faster processor will allow you to get faster results, if not, more memory and a faster processor.
