Save the project you are working on and adjusted the settings as different and clean the drawings in it. Save and exit. Transfer the project to your other computer, Computer/Local Disk(C)/Program Files/ideCAD/ideCAD Architecture 7/Templates Follow the path /Architectural and drop the file you brought from your other computer into the opened folder. Run ideCAD Architectural, click Project/New, you will see the file you want to draw with its settings under the Start using template option. Select it. Start using a template, create a new one with the settings you want. It helps to open the project page.
