Landing Level Problem on Stairs Created by Route Command
legasov
Hello, as I mentioned in the title, when we want to draw the ladder manually, we cannot adjust the landing level. Automatically, the last step and the landing level are equal, which prevents us from drawing the staircase in the architecture exactly. Is there a setting for this situation?
Re: Ask for Landing Level on the Ladder Created with the Route Command Hello, If you do not want the last step of the staircase to be at the same level as the landing, you can select the relevant staircase area in the staircase settings and uncheck the "Last step at the upper level level" option.
Re: Ask for Landing Level on the Stair Created with the Route Command
"Levent Özpak":ce1z985r" said:
Hi, If you do not want the last step of the staircase to be at the same level as the landing, select the relevant staircase area in the staircase settings and click "Last step". You can uncheck "At upper level".
Thank you
