You need to put the downloaded file in the Ladder library. For this, go to the directory where the program is installed and go to "C:\Program Files\ideCAD\ideCAD Static 8.61\ stair" Copy the file you downloaded into the stair file. Then start the program. From the Ribbon menu, select the ladder type you have transferred to the stair file from the Ladder -> Ladder Settings -> Ladder types."tasyapı":1v3rq1yd" said:hello, it says the file is in unidentified format and cannot be opened.
"tasyapı":1pwjba3b" said:thank you for your help, but this is not the staircase I want. I need to define the step number 9 in the drawing as well. I have attached the point I can reach with the route command. whatever happens happens on the 9 steps. I can also define it as a landing I want to give a step but a height of one step.
"tasyapı":18ebvhuk" said:the file you sent does not open. It says that I need to use incompatible version and updated version. I am using the latest version anyway. Also, the place I referred to as landing is 9 steps. It is not a landing. It is a single step on the ladder I sent. It doesn't happen when I draw with the route command like this. It happens when I draw as a landing. But I can't give elevation to the landing.
