Ladder size
celikbey
Hello. I am 7,018 user. I searched the forum about ladder metering. Asked but no clear answer. Whether it is solved together with the structure or separately, whether it is solved as a semi-rigid or full-rigid diaphragm, the formwork and concrete quantities of the staircase(s) are not visible in the quantity section (calculation axes are discarded and support conditions are also examined). But the equipment quantity is given. Is there a solution to this? Thanks.
The quantity of stairs is constantly requested and it really takes time to sit and calculate, especially if the type of stairs is too much. Earthquake calculations, reinforcement drawings, quantities etc. How is it that this program, which can handle complicated calculations like this, cannot measure a simple stair formwork and concrete? Believe me, it does not suit such a program... Do you not have any studies on this subject?
