Thank you for your attention. When I did the same, I was getting a warning that we had finished at the starting line of the exit line. Where did my mistake originate from?"NYILMAZ":1bxraear" said:Your ladder is as attached. Examine the lines made with the route command.
Thank you again."NYILMAZ":1b0v8ld9" said:Your exit line must touch the route object surrounding the staircase. If it doesn't, you can't create it.
