ladder fault
mhmt_ali
In the project I have done, I chose a ladder as seen in the figure, and after analyzing the Q8 iron reinforcement. Shouldn't it be Q14 or Q16? Can you help me?
The reinforcements are laid according to the design moments resulting from the calculation. If the required reinforcement does not meet the minimum conditions as a result of the design moments, then the minimum conditions in the Ladder parameters come into play. If you want to use 14 or 16 reinforcements, you can change the reinforcements from the Stairs Reinforced Concrete dialog. Good work
