night_fire
How do I draw the beams on which the landings of the stairs are located? When there is no beam, the reinforcements are drawn up to the end of the landing, normally it should go inside the beam.
Thank you for your reply I will."HakanŞahin":2aa8b3zq" said:Hi, The staircase system is modeled and solved as a shell, independent of the frame system. You cannot define the beams together with the staircase. Define the width and length of the staircase to include the beam widths. Thus, the reinforcement drawn on the landing should be in length to include the beam width. In addition, you can change the support properties to be restrained or free depending on whether they are beams or not. Then you can add beam contours in 2D or copy and paste the ladder into your mold plan in 2D. Take it easy...
