mass not found error in modal analysis 2 mass not found error in modal analysis 2, can you help me? If I have any other mistakes, I am open to suggestions, thanks. There is a 20 ton crane.
Hello, according to the project I added, although it shows the building as solving when I enter the crane according to the 2018 earthquake regulations, I cannot get any PMM rate or account report. I could not understand the problem. Looking forward to your help. Regards.
Hello there; There is a bug related to the cranes in this version and a note has been created for the necessary work. If you look at the screen after the analysis, it says that the analysis has been cancelled. Good work.
"MASS FOUND FOR ANALYSIS STATUS" WARNING HELLO EASY, WHEN PERFORMING ANALYSIS, IT SAY "NO MASS FOUND FOR ANALYSIS STATUS" AND THE ANALYSIS IS CANCELED. WHY IT CAN, WHAT CAN I DO...
Re: "MASS NOT FOUND FOR ANALYSIS STATUS" WARNING Hello; If there is a crane in your structure, it gives a warning in this way due to an error in the version of v10.14. If the crane is not present, you have a joint error or there are no elements in your defined floor. If there is no such thing as lack of personnel on the crane or floor, please send your project to [email protected]. Good work.
