Hello there; While the distributed loads on the composite flooring are transferred directly to the secondary beams and the main beams parallel to the secondary beam by sharing the area load due to the running direction of the flooring, load flow is provided to the main beams carrying the secondary beam through the secondary beam within the system. In short, load transfer takes place in accordance with the composite beam working principle. Good work.
