Junction cut safety report
mkrts88
What should I do if I want the junction zone interrupt security issue to appear at the top of the report? I mean, it says the elements with insufficient sections at the top, it normally says it on the lower pages, but I want it to say at the top and even say there are errors while creating the report. how do i do that thanks
"mkrts88":1j6zyz2f" said:
what should I do if I want the junction area interrupt security problem to appear at the top of the report, so it says the elements with insufficient cross section at the top, it normally says this on the bottom pages, but I want it to say at the top, even there are errors when creating the report how can I do this. thanks
Hello, the error message for Column-Beam Joint Interruption Safety(B) control is not given in the "Errors Detected in the Project" list. Problematic columns can be seen from the column reinforced concrete dialog before receiving the report. Good work.
Hello
"Levent Özpak":itasz0oe" said:
The error message for Column-Beam Joint Interruption Safety(B) control is not given in the "Errors Detected in the Project" list. Problematic columns from the column reinforced concrete dialog can be seen before receiving the report.
This Regarding the issue, (B) errors should not be given in the error message, but it has not been made even though I have written for years. I am writing this so that you do not miss it, correct it. At least now, an option should be opened for those who want it and they should see this error. Ünver ÖZCAN
