join ?
kth10
Dear colleagues, I could not fix the connection error of the S05 column on the upper floors except the basement in this project, can you help me urgently
If you pull the Sn kth10 S05 column up 10 cm, you get rid of the (B) error. Take it easy Unver ÖZCAN
solution suggestions: You can add curtains to the system in the 1-x direction. You can make 2-concrete class c30. 3- Solve the system as a semi-rigid diaphragm. i haven't tried this. because it gave a jacobian error in the analysis. I couldn't find the reason.
If 55/55 square columns are used, there is no problem, I do not think that there will be an architectural problem in the staircase area.
