Because of the two beams attached to the column in different sizes (25/60 and 60/32), I cannot ensure the shear safety of the junction area. I can't give any misalignment to the beam, I don't want to make the column thicker, it doesn't make any profit to interfere with the reinforcement order... However, after some thought, I came to the following conclusion. 1- Since the beam heights are different, the beam sub-reinforcements are already discontinuous. 2- In the upper reinforcement, half of the 60 cm wide beam reinforcements are discontinuous. Some will continue, some will be squared in the column. In other words, there is an approach towards the situation where As2 should be 0. The program, on the other hand, takes into account discontinuous beam reinforcements when calculating As2. This is why the interrupt security of the junction region does not save. When I uncheck the "Continuously accept beam on the right end" option, the problem disappears. But when you do this, the beam details are given separately. In reality, there should be partial reinforcement in the upper reinforcements. I would like to have your valuable opinions on the program's As1-As2 calculation and whether it would be a correct intervention for me to continually acceptme beams to deal with this problem. Respects.
