Jeans and floor height
Civil- engineer
I just started doing projects with İdecad. In the project I have drawn, when I want to define the windows on the ground floor, the foundation plan becomes active. I can't identify the windows to the ground floor. I guess I didn't enter the jeans correctly. The building is single storey. The raft will be the base. The project is attached. I'm waiting for your help.
Hello, the elevation and slope of the walls are wrong, the corrected project is attached Ünver ÖZCAN
Ozcan, thank you very much. Can you share how you did the fix? I also have a problem with jeans. When I want to draw a window, the basic plan view becomes active. But I will draw it on the ground floor plan. Why am I facing such a problem? Normally, -65 elevation is the upper elevation of the ampatage, +50 the upper level of the basement curtain and +4.04 the lower elevation of the beam.
Hello. :21x5sutd"] When I want to draw a window, the basic plan view is active. But I will draw it on the ground floor plan.[/quote] When you switch to the architectural mode, the program activates the floor below the static level, you will draw a wall on the ground floor, you can add an upper floor and draw a wall from the floor general settings. Unver ÖZCAN
