Jacobin error
Re: JAKOBIAN ERROR Hello, The system cannot be resolved warning is due to the absence of a nodal point on the beam at the point where the floor edge of the D04 slab in the basement connects to the K06 beam. Note: In the basement, the beams K02-03-06-08-10 have been given a positive level. However, no upper elevation was given to the columns to which the beams are attached. (Vertical continuity should be ensured by giving elevation on the next floor of the columns with an upper level.) Good work.
