Jacobian error
Connection error appears at several points. - beams are not connected to S36 column - There is an error in the console connection of ground floor beam K54. There is a piece of beam left in K35. - review the assemblage points by following the nodal points.
I solved this error, according to the analysis results, when some beams are enlarged, it gives again. I find the error again, I analyze again, I solve it, no problem, I change the size of the beam on another floor after a few analyzes, the same error appears again ... there is one more error right now, I am trying to solve it myself. It is interesting that when there is no error, just increase the size and the error occurs.
If there is a piece of beam remaining at the junction points, when you increase the beam dimensions, the beam will remain inside the junction area, and there may be a problem due to the size increase. That's why I suggested you check the ports. Because I remember it in a few places (like there are also curtain beam joints). If you look for deformations in any result you can analyze, you will catch some.
