Hi, on the 6th floor there are beams K1-K51, K2-K62 and K3-k62 and small beam pieces at intersections. Erase these beam pieces and connect the marked slab edges at the beam node. Some Notes: -It seems that the left slab edge of the d22 slab on the ground floor is not connected to the S16 column and the right slab edge is not connected to the K16 beam. (Try to delete and re-place the slab. You will see that the tile borders are wrong. -Some columns on the ground and mezzanine floors are sitting on the slab. In order to control the stapling in these columns, column caps must be placed under the columns by giving zero height and table height value. Also, D20 and D21 slabs on the ground floor should be placed. Reinforced Concrete Calculation Axis Edit command should be arranged as top + bottom flat reinforcement with the Reinforced Concrete Calculation Axis Edit command.
