Jacobian error
bha
Good day, I'm getting the ide build jacobian error, I couldn't figure out where there is an error in my model, I would appreciate it if you could help me
good work
A small piece of beam is formed in the area where the K21-K45 beams and the floor edge are connected. If the connection is made as in the example project, the analysis can be completed. Notes; *6. There is an inconsistency between the D02 slab on the floor and the elevation of the K61 beam. *It is recommended to model panel objects as shells. Good work
"bha":36dhdwit" said:
good day I'm getting the ide build jacobian error I couldn't figure out where is the error in my model I would appreciate if you could help me
good work
Hi K21 Cantilever beam is divided by K45 beam to form a short beam piece, Delete the Short beams on all floors and redefine by taking the axis of K21 Beam to the top This way you can analyze
"ahmetburakdemirel":18w3dvbg" said:
says where am I making a mistake, the system cannot be solved in jacobian and modal loading, I would appreciate it if you could help me
There is a short object warning in the Geometry control on the ground and normal floors in your project (K023 beam) When you correct this problem, the analysis is completed.
