Hi, Making the slab edge-to-beam connections from the beams joint and removing the empty joint points on the beam will solve your problem. It is marked which slab edge-beam connections are arranged in the attached project. Also in the project; -There is a piece of floor edge under the K56 beam on the ground floor. Static slab edge remained inside the D19 slab of the 1st floor on the 1st floor. -The right edge of the S02 slab on the 5th floor is not compatible with the floor level. Good work
