jacobian error help please
*Analysis can be done in your project in Ver 7.020. *When you define the eccentricity of the P28 panel at the bottom of 0.01 on the basement floor, analysis can be performed in 6 versions. You can download Ver 7.020 version from the link below.
Other than that; **The basic system created in the project is definitely wrong. (In this way, the effect of the columns sitting on the raft slab in the foundation design is not taken into account on the raft.) The raft slab borders should be formed with the slab edge on the raft-free raft foundation. In the rafter raft foundation design, all columns and walls must be connected to each other with continuous foundation beams. A raft flooring should be placed on the eyes formed in between. **It is recommended to model panel objects as shells. **You can analyze by checking the superstructure interactive solution option in the analysis settings. (A desired situation in TDY 2007 on C and D group soils) Good work
