Hi, -Your project needs more modes to ensure sufficient mass participation ratio, as the analysis is done according to the Seismic Load Method "Use response spectrum solution with eccentric moment loading in the diaphragm" option. If the analysis is made by selecting the "Apply the horizontal forces calculated by the method to the rigid diaphragm option" option, sufficient mass participation rate will be achieved with much fewer modes. With the "Ritz vectors" mode calculation method added in version -8, "Combination of mode contributions from Element-Specific results" is analyzed according to the earthquake load method. In the lower mode, sufficient mass participation rate is provided. Note: The stair arms on the right block are not connected to each other. Also, in order to support the stairs to the floors, analysis should be made according to the semi-rigid diaphragm option (In this case, the need for the number of modes will also increase) Good work
