Re: it says column buckling is not prevented..an urgent problem.. Hello, -Whether lateral translation is prevented or not, it indicates a situation, not a problem. In the calculation of the slenderness effect specified in TS 500 article 7.6, the effective length coefficient of the column and the moment amplification coefficient are calculated in case the lateral drift is prevented or not. -As for your project, check the stair support conditions. In addition, if the stairs are connected to the floor, it is appropriate to make a solution according to the semi-rigid diaphragm method. Good work
