It gives an error when editing the message and pressing the SEND button
When trying to edit the message that was previously sent in the forum, an error is given when the message is edited and the SEND button is pressed. "You must enter at least two survey options." (I would like to point out that this is especially the case when an attempt is made to add or remove images on the attached pictures.) An example error is also presented as a screenshot. Is this an error? If so, is there a solution? If not, what am I doing wrong? I'd be glad to help. ------------------------------------------------ Good work , Best regards. CONSTRUCTION ENGINEER EMRAH GOKDEMIR ------------------------------------------ ----
