My friend sent an e-mail to a project, when I examined the project, I saw that it was very poorly solved. Can you tell us the sides that do not comply with the EARTHQUAKE REGULATIONS.. and the floor numbers are in accordance with the regulation MU
Mr. Yunussacikk My suggestions: 1- The pile can be solved without foundation. No need for piles 2- 1. The stiffness sign will be removed because there is no stiffness in the basement 3- How to make the gaps in the hollow blocks
can be viewed here 4- Take the loads of the building stairs. (or you can make a semi-rigid diaphragm solution by taking into account the stair braces.) 5- Control the wall loads the same everywhere 6- Increase the width or height of the beams on the AF-1-7 axes outside the building 7- You can make a mezzanine for the elevator machine 8- basement curtains [i You can mark ] as "panel that does not continue on the whole floor"[/i]. Take it easy Unver ÖZCAN
