Is the pile-based project solution suitable? Can you review
xenix
I am solving a system with pile foundation for the first time. If there are mistakes or deficiencies in the project, I am waiting for your ideas.. thanks in advance.. I am giving it as a link because the file is a little big
Re: Is the pile foundation project solution suitable? Could you please review Hello. My suggestions -- the walls, including the attic, seem 12 cm aerated concrete. Check and correct, --enter the stair loads (since you have more floors, stair and wall loads may cause undesired negativities.) --you can reduce the raft foundation console --I would make the pile spacing equal. FROM THE FORUM FOR PILE How will the ground layers be
Calculating Pile Spring Constants
REVIEW. Take it easy Unver ÖZCAN
Re: Is the pile foundation project solution suitable? Can you review Thank you for your recommendations. I'm also wondering if the column and curtain sizes are sufficient?
