First of all, have a good day and good work. I want to remove the one between the columns between the horizontal leaves in my project, but when we remove it, it gives the love problem and there is a point that I cannot understand in the conflict control, where am I going wrong... thanks in advance for your help....
Re: is my lover design wrong Hello; First of all, if you do not want to use horizontal diagonals, you will need to enlarge the purlin sections on the roof. At the same time, you need to divide from all intersections with the join-divide command in the purlin menu. I implemented it in your project. When this division is done, lower pmm ratios will be calculated as simply supported beams. If you do not want to enlarge the section, use a cross. The reasons for the overlap problem are that you use reinforcement in both of the column-beam connections for the middle column and you have placed 3 bolts in the support joint. The beam body and the bolt overlap in the perpendicular direction to the beam. The way you can tell is that there is an overlap between the 2 elements that appear in red. You need to examine these two elements and intervene. On youtube idecad channel
