Is it correct to build the building with a floor height of 5.5 meters without curtains?
muhsin
hello... it is requested from me that the height of the ground floor of a 4-storey reinforced concrete building with an area of 40 square meters should be 5.5 meters. Is there a problem with this height, is it right for me to make this building without curtains (when I use a curtain, it gives the error that double reinforcement is required for the raft, how can I solve it? .thanks...
Re: 22.12.2014 help FLOOR HEIGHT 5.5 METERS It is difficult to comment on this building with so much information. If you add your project, experienced friends can comment.
Re: 22.12.2014 help FLOOR HEIGHT 5.5 METERS The ground floor of the building will be a cold storage. 18x24 square meters and the floor height of the other floors is 3m
Re: 22.12.2014 help floor height 5.5 meters Sn. muhsin, if you add the project, more useful information can be given, but if you do not do it without curtains, it is useful to see your system, but it is useful to see your system, B1 checks on the ground floor, also the spacing of the outer columns, infill walls, deformations, etc. These are important factors, good work
