yunussacikk
hello, there is irregularity in my vertical openings of the curtains. I checked the lengths of the curtains on the floors, they are the same. What should I do in the model to avoid this irregularity?
Hello, I think P17-18-16 and P24-P20 curtains You mean the continuity of the groups on all floors. The curtains are connected to each other at an angle. In the General Reinforced Concrete Parameters dialog, enter a value larger than the angle between the curtains, for example 15 degrees, in the line "Allow beams/curtains with small angle difference as continuous" (Max. -Also, for P32-28-25 frets to be drawn continuously with P24-20 frets, harmonize the viewing directions of P32-28-25 frets with P24-20 frets with the "Change/Beam-Foundation/Determine Object Direction" command. Good work"yunussacikk":3rxs49dn" said:hello, there is irregularity in my curtain vertical expansions. I checked the lengths of the curtains on the floors and they are the same. What should I do in the model to avoid this irregularity.
