Iron metering problem
eissenhover
hello everyone. I had an urgent question. The contractor company brought a project for the flagpole foundation. When I drew and analyzed the project with the same cross-sections, my iron quantity was doubled as the incoming project. After the analysis, when I enter the column menu from the reinforced concrete section of the program, change the radial foundation reinforcement manually while Q16/12 is in the middle, and make Q16/22, the color immediately turns red and (As-) is written in parentheses. he also says that the equipment area is sufficient, there is no problem until here. However, when I want to get the raft basic report, it gives a warning in the first window because of insufficient reinforcement, when I click OK and continue, all verifications are provided. If the reinforcement area is insufficient, how can all the verifications be "green tick" as well as positive? I am attaching the project as well. project information; ***there is a square raft with 410 cm on each side and a height of 85 cm ***there is a square column with a side length of 160 cm and a height of 155 cm in the middle of the raft ***a 5000 kg flagpole on top of the square column sitting. The anchor of the flagpole extends into the foundation. *** I have adjusted the concrete class to be c20, raft bars Q16, column bars Q20, stirrups Q8, ground floor 15000 kg/m2. These are the features of the project that came to me. Could you take a look at the 5000 kg flagpole installation I made to the column, I wonder if I'm wrong there. The quantity of the incoming project is basically a value like Q16/22 in both directions at the top and bottom. so in total 72Q16 is double in my report. Am I making a mistake, is it too late for a project Q16/12, I don't understand?
"eissenhover":381aeegr" said:
hi everyone. I had an urgent question. The contractor company brought a project for the flagpole foundation. When I drew and analyzed the project with the same sections, my iron quantity was doubled as the incoming project. When I go to the menu and change the raft base reinforcement manually while Q16/12 is in the middle and make Q16/22, the color immediately turns red and it says (As-) in parentheses. It says that the reinforcement area is insufficient, there is no problem. Because of insufficient reinforcement, all the verifications are provided when I click OK and continue. If the reinforcement area is insufficient, how do all the verifications come out as "green tick" as positive?
Hello, In the raft floor reinforced concrete dialog, the reinforcement fi16/22 is made and the report is received, Raft Basic Summary In the report, information is given as there is a basic foundation whose existing reinforcement is less than necessary. (If the existing main reinforcement is less than necessary status)
I am attaching the project as well. project information; ***there is a square raft with 410 cm on each side and a height of 85 cm ***there is a square column with a side length of 160 cm and a height of 155 cm in the middle of the raft ***a 5000 kg flagpole on top of the square column sitting. The anchor of the flagpole extends into the foundation. *** I have adjusted the concrete class to be c20, raft bars Q16, column bars Q20, stirrups Q8, ground floor 15000 kg/m2. These are the features of the project that came to me. Could you take a look at the 5000 kg flagpole installation I made to the column, I wonder if I'm wrong there. The quantity of the incoming project is basically a value like Q16/22 in both directions at the top and bottom. so in total 72Q16 is double in my report. Am I making a mistake.
Levent, first of all, thank you for the information you provided. As a result, according to the data of the program, it already gave us the minimum equipment for tem, a value like Q16/12. In this case, the equipment of the project that the contractor sent me is half missing. In the project I received, there is an equipment such as Q16/22 intermediate, which is very lacking in this case. Also, can you check if the upload I made for the pole is correct? As a point load, I had a -5000 kg effect on the top end of the 1.55-meter column. minus the z-axis as well.
"eissenhover":1lxxmio2" said:
Levent, first of all, thank you for the information you provided. As a result, according to the data of the program, he already gave us the minimum equipment for the base, a value like Q16/12. In this case, the equipment of the project sent to me by the contractor is half missing. There is a reinforcement like Q16/22 intermediate in the incoming project, which is very lacking in this case. Also, the loading method I made for the pole is correct, can you check it out. I had a point load of -5000 kg on the top end of the 1.55-meter column as a point load. It is on the minus z axis.
You can see the direction of the load from the analysis model.
