Internal and External Dimensions
The dimensioning menu is fully active on the model entry screens, and the inside-outside dimensioning is done very nicely. However, these dimensions cannot be transferred to the mold plan and dimensioning cannot be made in the mold plans with the same comfort. Shouldn't these quick dimensioning options be active in the mold plans? Also, no matter how much I correct the color settings in the drawings, when I export them as DWG or DXF, I don't want color changes. Axle names should be green, but red, individual base names should still be green, some green, some yellow etc. However, I always got the same result. I am seriously requesting a converter from you. Neither you nor I have time to fix so many problems. A converter that will allow me to open these models in the old version is the only thing that will work for me right now.
Mr. Furkan. Save your models in version 6 using the IFC export option. Then open it with the IFC import option in version 5.
"cassabotanic":2suuhlg7" said:
Furkan bey. Save your models using IFC export option in version 6. Then open them with IFC import option in version 5.
Thank you very much for your attention. I will try.
In version 5, it was possible to take interior and exterior dimensions in different colors in the drawing. But in version 6, such a possibility has been removed. I have the blueprint artist give thickness according to the colors. and I want outer dimensions thicker. how do i do this in version 6. How do I draw the outer dimension and inner dimension colors differently? thanks...
"oyuxel":1ogfxf5s" said:
In version 5, it was possible to have the inner and outer dimensions in different colors in the drawing. However, in version 6, such a possibility was removed. I make the blueprinter give thickness according to the colors. and I want the outer dimensions to be thicker. how do I do this in version 6 How do I have the outer dimension and inner dimension colors drawn differently, thanks...
Hello, You can change the dimension colors after you get the mold plan. Select the outer dimension block in the mold plan. Click the Object Properties command. In the block settings window that opens, select -Color change- mark and choose the color you want. Good work
