In the attached project, I wanted to define a slab between floors, but the upper beam overlaps the lower slab edge, and there was a warning of unsupported beams. where did i go wrong? can you help me? Thanks
I wanted to define a slab between floors in the attached project, but the upper beam overlaps with the lower slab edge, and there was an unsupported beam warning. Where did I go wrong? Can you help? Thanks
Hello, The edges of the lower level slab object divide the upper level beams. The order to follow when defining the slab; -Define the zero level beam and slab. -Turn off the beam and slab layer from the layer settings. -Disable the divide by intersections button in the tile edge utility toolbar (Let the slab edge in the y direction be a few cm outside the beam) -Define the mezzanine slab by opening the beam and slab layer and giving a negative level.
