Dear friends, Questions are asked in terms of the Program. Column: 1- How is the clamping length of the column shoots coming out of the foundation within the foundation calculated? Beam: 2- Is overlapping made on the beam? The regulation did not allow for towing areas, if so, where is it done? 3- Is "lb=0.12*fyd/fcd*diameter" used as Straight Overlap length in the beam? or "1.lb= (0,12*fyd/fcd*dia)*1.4" is used according to Position-I. That is, is the Position-I formula applied? 4- When bending of the beam reinforcement occurs (inside the column or when it encounters a beam of different height, that is, in the case of TDY 3.4.3.1), is "lb=0,12*fyd/fcd*diameter" used as the Overlap/Clock length? or "lb= (0,12*fyd/fcd*dia)*1.4" is used according to Position-I. 5- TDY2007-3.4.3.1.(b) states, "In case the beams join the columns from both sides, the sub-beam reinforcements shall be extended at least as much as the clamping length given in TS-500, not less than 50 ft from the column face adjacent to the opening." Does the program implement this? 6- Beam parameters / Rebar transitions / Extend upper reinforcement to adjacent opening: ln/xxx / Extend lower reinforcement to adjacent opening: ln/xxx Is it necessary to mark and enter values for TDY2007 and TS500? Is it taken into account in the calculation of clamping and overlapping lengths when it is marked and a value is entered? Should it be taken? 7- Does it make Overlaps as desired by TS500? 8- In the addition (overlap) of the tensile reinforcement, Lo=alfa*lb alfa=1+0.5r r: It is defined as the ratio of the reinforcement added in the same section to the total reinforcement. Does the program calculate alpha? Where does he use the formula lo=alpha*lb? 9-General Reinforced Concrete settings / Coupling Reinforcement Attachment / When the Use coupling reinforcement attachment when equal and larger is checked, what will this affect (In Beam, Column, Foundation, etc.)? Does it reflect in my drawing? General: 10- Is there anything that the program does not do about clamping and overlapping length, but the user should do? 11- What would be more appropriate to intervene before and after analysis, before and after drawing in the parameters of the program related to clamping and overlapping length? 12- TS500-9.1.2.1 "In cases where the concrete cover is less than the diameter of the reinforcement or the net distance between the reinforcement bars in the same row is less than one and a half times the diameter of the reinforcement, the clamping lengths calculated from Equation 9.1 should be multiplied by 1.2." says. Does the program pay attention to this situation?
