memorandum
Hello, When we design a Steel Building, when I enter the foundation as a raft, I usually get the warning of insufficient thickness. The raft, which should be 35 cm-40 cm, saves min 75 cm. When I design the same steel floor as reinforced concrete and enter the same foundation, it saves. What is the solution to this? Good work..
