Insufficient raft base reinforcement error
fth_fth
Dear forum administrators, as I mentioned in the title, I could not resolve the raft basic reinforcement insufficient error. I couldn't solve it even though I decreased the intervals for not increasing the reinforcement diameter. I'm waiting for your help. Good work .
Hello My Suggestions: In the project you added, without making calculations, additional reinforcement Q14 was removed from Q20 in sections that did not save, the situation was improved when additional reinforcement gaps were made Q20/8 in one section in X and Y directions. Unver ÖZCAN
When I have the analysis done again after correcting the additional reinforcements, it goes back to its original state. Is it possible to fix additional equipment?
"fth_fth":xts4dm08" said:
returns back to its original state when I re-analyze after fixing the additional reinforcements. is it possible to fix the additional reinforcements?
Hello, Raft basic additional reinforcements are not fixed. In your project, in the Rebar selection dialog, it is only 14 ' for additional reinforcements. The diameter is selected. Select the diameters of the reinforcement you use while editing. In the raft parameters dialog, change the additional minimum spacing value to the value you are editing. In this case, AS(-) warning will not be given when the analysis is made. Additionally; Raft reinforcement axes and working distances are parallel to the global X and Y axes. I recommend that you arrange it in such a way that the raft foundations are ampathed, which contributes to the reduction of the need for additional reinforcement.
