hello I'm getting an insufficient number of modes error in dynamic analysis project link;
Log in or register now.
There is a data entry error in your project The curtains defined in 3.4.5.6 axes on normal floors are not defined on the ground floor."samet1":1341q6i0" said:hello I'm getting an insufficient number of modes error in dynamic analysis, how can I fix it? project link;You do not have permission to view link Log in or register now.
Hello, there is a lack of mods in the basement floor.You can see this by examining the 'Vibration mode count proficiency check' report in the dynamic analysis reports Increase the targeted modal numbers of Modal BE1 and Modal B' modal states from the structure tree to a level sufficient in both directions.Some notes about the project: -Continuous foundations connected to the walls in the rigid direction will be connected from the wall end joint point to the other end joint point and remain under the curtain. -Some of your floors have problems at the junctions with the curtains.Delete these floors and define the empty areas so that there is floor space. 'Use design spectrum for vertical earthquake effects' option is checked on beams. This option does not need to be checked in the project. You can review TBDY 2018 Article 3.6.2.4 and Article 4.4.3 related to the subject. -In the project, the tooth gaps in the cassette floors seem to be above the limits specified in TS500. You can check the links below on the subject."hkaragoz":3m903wmb" said:Hi there; I am getting insufficient number of mods in my project. I am waiting for your help to fix it. I would also like to get the opinions of friends if there are any in the project. Thank you...(project link is below.)You do not have permission to view link Log in or register now.
